I got a problem when creating the backing sheet on PDMS.
KINDLY CORRECT MY PROCEDURE, i think theres something worng on it.
After creating the backing sheet from Autocad and naming my and naming the following to
Draft Sheet Library Name: BS
Backing Sheet Name: BS1
Draft Command Filename: C:\TEST
Then going to Draft module/General Admin/ Sheet Libr
Draft--> Sheet libraries
Then under Registry -- Create-->Library
Create--->Sheet library
Then after creating Sheet Library, on the Command line of PDMS i put
$M C:\TEST\BS1 OR $M C:\TEST
But the output is Error or File not found or Undefined name.
Can you help me guys regarding this matter so i can use my backing sheet that i have created from ACAD.
Thank you so much on Response
Check this Dear All
[INDENT]Login to Autocad
1) Take the backing sheet(existing or draw the new one) of required size for Ex:A0 in autocad.
Check the limits in the lower left limit is 0,0 and upper right limit is 1189,841.
now move the left lower corner of the sheet to 0,0 and save the work
2) now explode all the contents in the sheet.
3) APPLOAD the sheet into pdms,when you try to appload browser window will popup,browse to
C:\AVEVA\Pdms11.6.SP4\autodraftACAD and select all the lsp files and say load
4) Now enter command PDMS_SHEET .you can see the following in command window
Select all items to be made into a PDMS Backing/Overlay Sheet: select all the objects
