When in draft, the equipment is showing in the 3d view as it should but in the 2d view the only components that are showing are all of the nozzles to the equipment.
I've read through the DRAWING PRODUCTION user guide and the DRAFT user guide and I didn't see anything at all about the 2d view singling out components when everything is shown in the model. I also did searches here but I couldn't find anything that matched my problem. I've tried adjusting attributes, view type, and anything else that might work but I still havn't stumbled on a solution. Is there a layer that I have turned off somewhere that I can adjust?
Make the VIEW your CE.
On the command line type: GOTO RRSF
That's the representation rule you are using.
It contains many RRUL elements.
Check the style (STYF attribute) of the one regarding equipments...
Attributes
Name /DRA/PRJ/STYL/EQUI/NORMAL
Type STYL
Lock false
Owner /DRA/PRJ/STYL/EQUI
Tubeflag On
Cline On
Psymbols On
Obstflag Off
Insulation Off
Profile Off
Plines Off
FFStyle Solid
FFColour Green
BFStyle Off
BFColour Grey
CLStyle Chained
CLColour Green
ObStyle Off
ObColour Grey
PLnStyle Off
PLnColour Grey
MLnStyle Off
MLnColour Grey
Dlevel 6
