How to Provide dimension along a inclined view?
  • hi!Darkdarkhbk!
    did you have solusion for this? Please! Share your opinion.
  • NEW ADIM-->Create new Angular Dimension element
    ON ID @   -->Use cursor to nominate the Design item used as the Dimension's Origin
    FROM @ TO ID @ -->Use cursor to nominate Design items defining the first and second Dimension Directions.
    DPOS @ --> Use cursor to nominate a sheet position through which the dimension arc will pass.
    For PLINES
    NEW ADIM -->Create new Angular Dimension element
    FROM DIR IDPL @ TO DIR IDPL @ --> Use cursor to nominate plines defining the first and second Dimension Directions.
    DPOS @ -->Use Cursor to nominate a sheet position through which the dimension arc will pass.
    [COLOR=#FF8C00]DPOI Elements SEQUENCE[/COLOR]
    NEW ADIM
    ON ID @
    FR POS @ TO POS @
    [COLOR=#FF0000]ADIR  dimension sequence
    [/COLOR][COLOR=#000000]NEW ADIM
    ON ID @
    FR DIR N30E TO DIR S20W[/COLOR]
  • hi!deva !
    I think your instruction for Angle Dimension not for Liner Dimension or Align dimension
  • 45 degree rotation is it come into inclined right...
  • hi thienth,
    for vertical dim you can use this command 'NEW LDIM DIR D'
    for horizantal dim if you are looking view in 'N' then 'NEW LDIM DIR N'
    Yadav....
  • Hi thineth,
    I am giving the Align Dimension instruction.....
    first creat NEW LDIM Use cursor to nominate plines defining the first and second [COLOR=#417394]Dimension[/COLOR] Directions.
    Be on LDIM (which was created in LAYE) then
    enter the command 'TLINDICATOR TRUE' for liner position,
    enter the command 'DTANG PARALLEL' for text position.
    Yadav....
