Inteligent Text: Elevation in meters and with 3 DP
  • Hello everyone
    I have a Symbol with the inteligent text: "EL. #POSU+"
    but, usually, the projects are made in meters and it's common to annotate the elevations in meters, independent if the rest of the dimensions are in millimeters.
    well... how do i do the Inteligent Text to be in the form: "El. +1536.200" where: 1536.200 is the elevation 1536200 in millimeters?
    thanks in advance
  • [QUOTE=Christiansen;66948]Hello everyone
    thanks in advance
    Hi Cristiansen,
    You can always set the layer units. Modify layer attributes and set distance unit to Meters.
    HTH
    alinofeire
  • Hi alinofeire, as [COLOR=#000000]I understand some function convert the values from meters to milimeters. Do you know how to convert not to meters but reduce it?  As an example: 1200,234   but I need -1200,235   and if 1200,238 we should abtain -1200,24
    I can write some  macros that will transform picked value but maybe there should be standart one..[/COLOR]
  • [quote=christiansen;66948]hello everyone
    i have a symbol with the inteligent text: "el. #posu+"
    Well... How do i do the inteligent text to be in the form: "el. +1536.200" where: 1536.200 is the elevation 1536200 in millimeters?
    Thanks in advance
    el. #posu(c1:4).#posu(c5:)
