Hi, i want to generate PAD but there is a problem. An error will prompt saying that "VIEW /032AD1202/S1/V1: Invalid limits caused by incompatible section planes"
What u mean from generating PAD?? r u trying to create a PADD DB or r u trying to generate a Limits defined View???
From error it seems that you are trying to generate a Limits defined view.
Check by changing limits of the view to Limits : ------> Drawlist members & after that againg select a view direction..
If you still face a problem then post some snaps so that it would be easy to understand the exact problem....
Section planes are nothing but cutting planes used to capture the image set within those planes.... Please go theough the draft manual.. Read user defined views & Limit defined views.. You will find the answer in that.....
