Draft Module Label setting
  • Replies 7 replies
  • Subscribers 5 subscribers
  • Views 37 views
Label setting
Joke
Joke over 12 years ago
  • Joke
    If anyone knows how to write a label # POSZ+ minus some value.
  • Eric Callis
    Eric Callis over 12 years ago
    I'm pretty sure you can't do intelligent math in labels. What you could do is store a formula in a uda then write a macro that would update all labels with formulas.
  • Barry Bertram
    Barry Bertram over 12 years ago
    You can get the difference between do values which may help?
    the =ref numbers will need to be changed to two elements in design
    #PKTOS^POSSN+
  • Joke
    Is it possible to explain with more detail .
  • Ilgiz Kalimullin
    Ilgiz Kalimullin over 12 years ago
    you can't write a label # POSZ+ minus some value.
    you can create an element on some positionZ and then you can write a label # POSZ+
  • Joke
    Thank you very much.
  • Sri
    Sri over 11 years ago
    [QUOTE=Baz90;68926]You can get the difference between do values which may help?
    #PKTOS^POSSN+
