Draft Module LEVEL to hide objects in draft
  • Replies 5 replies
  • Subscribers 5 subscribers
  • Views 13 views
NAGENDRA VUDDAGIRI
NAGENDRA VUDDAGIRI over 12 years ago
  • Admin
    Admin over 12 years ago
    Quick way would be to remove them from drawlist attached to your view, time consuming if you have many.
  • NAGENDRA VUDDAGIRI
    What level we have to set if we wish not to generate those objects in draft?
    For example,
    Under SUBE i had couple of CYLI & BOX
    I want to generate a drawing of CYLI only, in this case what level we have to define for boxes?
    The problem is here i dont have control in draft.
    So i am looking a way to control from design
  • Juan Manuel Gutierrez Valderrama
    Juan Manuel Gutierrez Valderrama over 12 years ago
    It depends of the settings in draft,  check with level 0 but at the end it depends on the settings of Representation styles and rules you're using.
  • RAVI KUMAR
    RAVI KUMAR over 12 years ago
    Level 2 10
