Draft Module dimension
  • Replies 11 replies
  • Subscribers 5 subscribers
  • Views 23 views
dimension
Kiran B. Bachhav
Kiran B. Bachhav over 12 years ago
  • Kiran B. Bachhav
    Hi.
    I want to give dimension from Column to Platform Opening how we give it
    because platform opening not taking point for selection.
  • Sri
    Sri over 12 years ago
    goto measure >> take graphics-midpoint combination and select centre  line of your plotform opening.please make sure you in wireframe mode to get good result.
  • Venkata Rao Peta
    Venkata Rao Peta over 12 years ago
    Try with P-Point Option.
  • Kiran B. Bachhav
    sorry but it is in draft not in design i forgot to mention that point.
  • Venkata Rao Peta
    P-POINT and mid point options are avaialable in draft also, while creating dimensions this options will appear
  • Sri
    In draft also you have one option called mid point,end point etc.try these options
  • Kiran B. Bachhav
    when you click on platform opening it is not showing mid point or end point.
  • Venkata Rao Peta
    Try with P-Points.
  • Kiran B. Bachhav
    platform opening don't have p-points
  • JMM
    JMM over 12 years ago
    If a NEG was used to cut the opening it has a P-Point.
