Hello everyone,
I would like to submit a problem hoping that some other user has happened.
Must generate a 2D plan view UP, typically use two methods to generate the visa or Module "General" or the Module "AutoDrawingProduction."
If I create my vision with the general method it takes a long time, so I opted to use the method of "AutoDrawingProduction."
Here, however, risk making a big deal, but to explain myself better you list the steps that I do:
1) I create the view
2) I insert in my Drawlist the PDMS Site including all the elements that I want to present in that view
3) I insert the bounds (say, for example, that the cuts are elevation from 0 to 100).
4) I create the view
Here once this process is happening to me this problem:
"I generates the view with all the elements not only from 0 to 100, but also over until Over" However, with regard to the Pipe I carries the tag only Pipe of from 0 to 100 ".
You tell me why?
Problem setting style? (Universal Hidden Line, Global Hidden Line, Local Hidden Line, ...).
Thanks in advance,
Mr P.
