• PLT format doesn't work with Trye Type Fonts.
    You can read C:\AVEVA\Plant\PDMS12.0.SP6\Manuals\Docs\PDMS User Bulletin12.0.pdf 2.9.6 PDMS Plotfiles
    Have you tried asking Aveva France Support Team?
  • hello,
    is it possible to integrate a barcode on an isometric?
    my method is as follows: in draft module, create a backingsheet with TTF "code 39" , generate a plt of it and integrate this plt on my isometric as a dynamic detail
    But when i generate the plt, nothing appears
    is anyone have a solution?
  • I try but they told me that it was very long and very complicated (and should be paid)
    So according to you it is not possible to integrate a barcode on an isometric?
  • Sorry. I don't know. I have never experienced such kind of request before....
  • I saw this post late.. I have a batch file which generates barcodes. It run for me well. Some adjustment is required in file path. Following files needed , barcode.lsp mfind.lap (to be saved in ACAD folder) IDAutomationHC39M.ttf
    The barcode is written in Isometric through Autocad scripting method.
    1. Create own Iso create form.. You need to stop Iso repeating numbers like 001, 002 003 etc, It should always generate 001. Otherwise it is difficult to locate file through PDMS batch.
      FILE DXF /Z:\CAD\PDMS\Project\bdo\pdms_dbs\BDOinfo\DXF/$!filename- SINGLE DETAIL /$!filename
      Exit
      syscom |copy "Z:\CAD\PDMS\Project_Files\Barcode\BDO_BarCodepdms.bat" "c:\temp\script\$!filename-.bat" /y|
      syscom |"c:\temp\script\$!filename-.bat"|
    2. create a DOS batch file BDO_BarCodepdms.bat at above mentioned folder. This will be master batch for each iso. add following code
    @echo off
    set fpath=Z:\CAD\PDMS\Project\bdo\pdms_dbs\BDOinfo\DXF
    set acadpath="C:\Program Files\Autodesk\AutoCAD 2011\acad.exe"
    ECHO ------------------------------
    set fname=%~n0%~x0
    set fname=%fname:~0,-5%
    set fname=%fname%
    echo.%fname%
    if not exist %temp%\script md %temp%\script
    set scrpath=%temp%\script
    if exist %fpath%\%fname%-001.dwg del %fpath%\%fname%-001.dwg
    if exist %scrpath%\%fname%.scr del %scrpath%\%fname%.scr
    set STRING1=(Load "barcode.lsp")
    set STRING2=(Load "mfind.lsp")
    set scrfile=%scrpath%\%fname%.scr
    echo Generating and Adding Barcode in drawing..... Please Wait......
    echo _.Open "%fpath%\%fname%-001.dxf">>%scrfile%
    echo _.Zoom _E>>%scrfile%
    echo %string2%>>%scrfile%
    echo (CommandMFind "ISOID:" " " T T T T T nil nil)>>%scrfile%
    echo (CommandMFind "%line%" "" T T T T T nil nil)>>%scrfile%
    echo %string1%>>%scrfile%
    echo style  IDAutomationHC39M 4 1   >>%scrfile%
    echo text 352.7,6.5,0 0 %codename%>>%scrfile%
    echo _.Quit   >>%scrfile%
    echo _.Quit>>%scrfile%
    start "Stating ACAD" /min /wait %acadpath% /b %scrfile%
    exit
    3.  in Isopreviewstdinch.txt file add a code for barcode.. wahtever you wantedas barcode
    TextPosition |ISOID: $!ctrnum-$!C-$!D-$!E-$!F-$!G-$!revn| X 1'2in Y 0.1/4in CharHeight 0.1/16in
    4. ISOID: (and one space) needed for acad script to find replace text. This is required to omit barcode text in dxf file and replace the same with barcode font.
    That's it...
