  • first set the limits to the sheet.
    lower Limits (0,0)
    Upper Limits (1189,841)
    Limits Command in autocad Command line will give the Limits.
    After this try to Import(Make sure your sheet contain Poly Lines and straight lines, if arcs are there means it is very difficult to outline)
  • Dear  kubik
    yes  import from auto cad to draft .
  • Dear  deva
    i have set  limit , also explode object in autocad file
    but one problem is there front / compny block is not see in draft  .
    How can resolve problem ?
    Its urgent .......
  • you have to outline Company Block (LOGO) in autocad with the help of Lines. (STRA)
    If LOGO having any ARC then you have to draw those with small Lines. Don't use any HATCH pattern.
    Explode all Hatch before exporting drawing.
