[QUOTE=jschleier;73797]when i open my dxf file up in autocad 2011 (that dxf file i created from pdms) the text is scaled up way to big and is outside my border?
it never used to do this with earlier version of autocad..
anyhelp?
Check here : http://52.178.132.139/showthread.php?t=15024
;;;NEW TEXT STYLE Arial
-Rename
S
TTFN5
SPCX-Arial
._STYLE
SPCX-Arial
Arial
3
1.0
_NO
_NO
;;;CONVERT TEXT SMALL
(defun c:txt_ht (/ a ts n index b1 b c d b2)
(setq a (ssget "_X" '((0 . "TEXT") (40 . 3.925))))
(setq ts 2.2)
(setq n (sslength a))
(setq index 0)
(repeat n
(setq b1 (entget (ssname a index)))
(setq index (1+ index))
(setq b (assoc 0 b1))
(if (= "TEXT" (cdr b))
(progn
(setq c (assoc 40 b1))
(setq d (cons (car c) ts))
(setq b2 (subst d c b1))
(entmod b2)
txt_ht
in the 2nd part, change the 3.925 in the 2nd code line (in function of the too big size of your text) and 2.2 in the 3rd (in function of what you would like).
