if you have a drawlist set up you like and want to put it on many drawings the easies I way I know to do this is copy the drawlist member to each DLLB.
Go to a drawing you like the drawlist on and navigate to the LIBY > DLLB
in the command line type
VAR 99 NAME
then go to each drawing want copy the drawlist to and navigate to it's DLLB and using the menus up top, do a Delete > Members
then copy the drawlist over using this in command line...
copy members of $v99
this is faster than it sounds, you can do a lot drawings quickly.
i assume you are trying to explain copying drawlist to mulitple drawings..... Whereas my issue is to fix multiple drawlists which are having unknown references
