Draft Module MODIFY dra-genadp-piping
  • Replies 9 replies
  • Subscribers 5 subscribers
  • Views 25 views
DANTE OLEIVERO
DANTE OLEIVERO over 12 years ago
  • Admin
    Admin over 12 years ago
    I think if you are talking about representation levels then this is regarding Style and Rules libraries but not a ADP functions
  • DANTE OLEIVERO
    Dear, someone could help me modify the dra-genadp-piping, for production autodrawing, I just want to appear in the ceterlines level of equipment, and not the dimensions. Thank you.
  • DANTE OLEIVERO
    default file-genadp dra-piping, limits and centerlines to put equi, I want to modify it in such a way to turn off the dimensions.
    thanks
    You can try defining a dummy rule for Annotation Type 2 so that no dimensions will be generated.
    And set your file so that dimension/projection lines are not copied from other Annotation Type (1 & 3).
  • DANTE OLEIVERO
    thank you very much for your response corrado, but it has worked, I created a Dummy rule so as not draw lines of projection or the dimension, but equally does not draw the center lines.
    any other suggestions?
    Make sure you have selected the Equipment Centerlines option in the Type2 Annotation form.
    Make also sure you get a Layer with PURP attribute equal to ADEA
  • DANTE OLEIVERO
  • DANTE OLEIVERO
    The picture you have attached is not readable.
    Could you please post a better one and maybe some other ones so we can better understand what is going wrong?
    Do you get any warning/error message on the command line?
