Draft Module Welding for Bend
  • Replies 6 replies
  • Subscribers 5 subscribers
  • Views 10 views
Welding for Bend
LEANDRO
LEANDRO over 12 years ago
  • LEANDRO
  • Venkata Rao Peta
    Venkata Rao Peta over 12 years ago
    we faced longback the same problem, bends large dia bends,mitered bends will not get a weld and a dividing line also won't appear, bend will considered as pipe in this cases.
    if these are elbow components it will not give any problem.
  • Venkata Rao Peta
    http://52.178.132.139/showthread.php?t=10396&highlight=mitered+bend
    What do you mean when you say "Of particular Eblows in the model were loaded as "Bend" in Piping Class" ?
    Could you please explain in detail which kind of component/connection you need to manage?
    If you really need a weld in that point, why don't you create a real WELD element?
  • LEANDRO
    Thank you for the information.
    So if I understand in this case in my print screen will not bring up the weld between pipe and Bend?
  • LEANDRO
    Hi Corrado.
    I spoke with the client and in the end we agreed that it considers proper to convert the components of type in Bend in Elbo.
    I'm going to create a macro that will change me all the types of the components concerned, from Bend to Elbo so that they can appear welds in Draft.
    Subsequently'll update the Piping Class in order to solve the problem permanently.
    I'll just have to solve the problems that when I change the type of component in Design I do not appears in the section of tube(but if I make a move By X 10 and By x -10 I I get the tube), but this is not the appropriate section to talk about this issue.
    Thanks for the advice.
