Don't need bolts? Just set BSEL on Flanges to the value that is obviously not in Bspec. Like UNSE. Then system will not select the bolt cause it will not find it
If I got your problem right
I realized that even if only a flange model generates me the same problem as a result I think the problem is the specification and not on the component.
I accidentally inserted this post in sezioen Draft, politely ask the administrator to move this post in the section of Paragon.
If your valv has no flange then there is no bolting. If you need so then use additional MTOREF but you will not get length and quiantity. Only to put manually
The value of Boltselector is "unset".
According to this model if a valve with no flange I should buy the Bolt.
I can not if the mistake was on the piping class or bolt specification
