Draft Module curve plate length
  • Replies 11 replies
  • Subscribers 5 subscribers
  • Views 17 views
curve plate length
francis dela cruz
francis dela cruz over 12 years ago
  • francis dela cruz
    H,
    good morning.
    I'm just wondering if we can get the arc length of a curve plate to show using an intelligent text.
    I can get the height and thickness of the plate in the intelligent text.
    hope some can share their ideas on how to fix this.
    thank you all in advance.
  • NAGENDRA VUDDAGIRI
    NAGENDRA VUDDAGIRI over 12 years ago
    which element you used for that curved plate? like Revolution?
    and if possible post the pic of the same
    With 12.1.SP4 you will have a new element called "Bent Plate"...
  • francis dela cruz
    thanks for your reply
    I'm using a gensec for the curve plate. and its geometry is similar to a half pipe.
  • sergey_b007
    sergey_b007 over 12 years ago
    Hi
    may be you can use attribute: frad (radius of vertex,curve)
  • francis dela cruz
    Thanks for all your replies. on my gensec (curve plate) I did not see any frad on the attributes at gensec and spine level.
    we are using SP6.4 where can I find this bent plate?
  • sergey_b007
    do you can not use CURVE LEVEL?
    Curve has attribute radius.
  • francis dela cruz
    yes, thanks I found it. it is in the curve level. can we perform a mathematical expression to get the length of the curve? to show in an intelligent text?
    [QUOTE=fddelacruz;78785]Thanks for all your replies. on my gensec (curve plate) I did not see any frad on the attributes at gensec and spine level.
    It is a new element that will come out with 12.1.SP4 in a few days...
  • sergey_b007
    I think it's go only with macro. That's just one example:
    var !cur coll all curve for ce
    do !i val !cur
      $!i
      var !cpos cpos wrt/*
      !poscur = !!ce.pos.wrt(worl)
      prev
      !posp1 = !!ce.pos.wrt(worl)
      $!i
      next
      !posp2 = !!ce.pos.wrt(worl)
      var !h1 const dist $!posp1 to $!posp2
      var !h2 const dist $!posp1 to $!poscur
      !dlhor = (2 * $!h2) + ((1 / 3) * ((2 * $!h2) - $!h1))
      !dd = !dlhor.string('d2')
      $P Length of arc = $!dd
    enddo
