Draft Module problem with texts in Draft module
  • Replies 9 replies
  • Subscribers 5 subscribers
  • Views 1 view
Camila Thaís Nerbas
Camila Thaís Nerbas over 12 years ago
  • Camila Thaís Nerbas
    I brought to my project a Drawing by "Datal", the drawing content and the backing sheet are OK, but some texts of the backing sheet do not appear, as the title ...
    the attributes of the Sheet are filled such as in the original Sheet.
    Please, somebody help me?!
    Tks!
    Camila.
  • Sam Anand Joseph
    Sam Anand Joseph over 12 years ago
    Take a report of all the texp and the font type. If the font shows 999999, then change to 1. It will appear.
    Hi Samjoe3,
    The problem is not this. But the text simply doesn't appear...this texts are UDAs filled.
    mistery...
  • Admin
    Admin over 12 years ago
    You say the texts are UDA filled, are the UDA's in your current project?
  • Admin
    I believe yuo have done command UPDATE ALL?
  • Sam Anand Joseph
    Hi Camila
    Can you give an example of the problem font. I will try out and let you know. I am not an expert, but I had some problems in Draft font which I cleared out. If your problem is one of what I had encountered, I thought I can help you out.
    Cheers!
    Yes, The UDAs are there...
    I tried UPDATE ALL already....doesn't work! Tks!
  • Admin
    Can you go to the item with text
    is it texp and query q btext
    wht is the result
