i am trying to output DWG from Draft 12.1, result is really strange - dashed lines from Draft are now wider polylines at DWG.
I have tried many settings and did many searches at manuals and PDMS environment, but no result ...
I hope somebody will have solution :-)
Check which switches you have set for the dwg output. If you have switch PrimitiveThickness 'ON' you can adjust switch PlineWidthFactor '0.2' to adjust thickness. Should be 0.0 - 1.0 for thickness.
Thank you for reply. Manual for draft 12.1 say:
PlineWidthFactor - DEPRECATED: this option is no longer in use and will be ignored.
Still searching for solution, i case i find it i will write it here...
T.
Try with LTSCALE varible in AutoCAD. Probably the line is scaled wrongly. I can not believe the dashed line is interpreted as solid in CAD. If so with all settings properly set in PDMS and if the appearance is still wrong then Aveva should have a look on it.
