hi try this solution:
1. check drawlist --> delete invalid drawlist
2. under view delete vsec ( 6 item) using commandline -->delete vsec
3. after you delete vsec under view check LIBY ---> PLLB---->FPLA (this FPLA will automatically deleted also once you delete vsec, if not delete manually using ocmmandline.
4. click on view --> as your ce then modify-->view-->limit defined
5.limit defined view dialogue box will appear, select Limit, the put check to all E, N, U then click "update grapical aids" then tick "update design' then "apply"..
hope it solve your error..
while copy of view & rename, what are the steps to be followed ?
can anybody explain, in detail?
I found some link between LIB, DLLB, is disconnect. how to rectify it ?
