Draft Module GLAB Issue ( #NAME)
  • Replies 5 replies
  • Subscribers 5 subscribers
  • Views 10 views
GLAB Issue ( #NAME)
Craig Watson
Craig Watson over 11 years ago
  • Craig Watson
    Hi hopefully there is an easy solution for this
    Working in draft I would like to use the (NAME) as an output for my GLAB so I can see =222222/444444 etc, on the drawing sheet
    I can get every other label to work apart from #NAME
    The label come out with     _ _ _
    Any suggestions
    Thanks
    You get --- because the element you have attached a GLAB to is unnamed.
    If you want =222222/444444 then you can try with #REFNO
  • distyler
    distyler over 11 years ago
    or #NAME
  • Admin
    Admin over 11 years ago
    A short comment. For the Null text which is the text displayed if the intelligent text could not be taken, the Ntext attrbiute is responsible.
    When you create a shee and view there are several Layers automatically created. Laye has mentioned Ntext attrbiute.
    Then if you check for PDMSDFLTS folder you can find a dra-gen-lablay file. This is the file which stored some defaults used on label layers creation. So if you put there a command
    Ntext '#NAMN'
    then all layers will have Ntext set to '#NAMN' and that means that if you label something and I-text you put could not be calculated then the system will take value from Ntext so #NAMN
  • Craig Watson
    Thanks
    I got #NAMN to work
