Draft Module
How to convert drawings to Auto Cad 2D
5 subscribers
Arun Kumar
over 11 years ago
Arun Kumar
over 11 years ago
Dear Experts,
Can we convert the draft into auto cad 2D (.dwg) file?
If so, Please explain me the procedure to do the same.
Regards,
Arun
Marvin O. Gonda
over 11 years ago
Utilities > Standard DXF CE or Configurable DXF/DWG CE
Arun Kumar
over 11 years ago
Thank you...
Arun Kumar
over 9 years ago
Dear Friends,
I have got a new problem in converting the PDMS draft file into Auto CAD file.
While converting a file in a registry, the PDMS is giving fatal error.
This is happening for one particular file in a registry and other files have no problem to convert.
Kindly give some suggestion as recreating the said file will take lot of time.
Regards,
Arun
Miguel Lourenço
over 9 years ago
Hi Arun,
By file you mean drawing? What is the error?
Arun Kumar
over 9 years ago
NAGENDRA VUDDAGIRI
over 9 years ago
check your command line.
If there any errors with the drawing, they will show up there
Azmatulla Mirza Baig
over 9 years ago
Do graphics update all for the drawing file and try output to dxf file.
If the problem persists.
Delete the drawing registry and create new one.
Kimberly Miller
over 9 years ago
I am having similar issue... I am trying to export configurable DXF/DWG to a DWG... but need to change the scalefactor to 1.25. when I do this some of my pipe is not scaling properly. Any suggestions?
