If user provide anything then this is not default I think. Default is something that is set once for the project and used on creation.
To set default you can use following
Go to your PDMSDFLTS folder
find file called dra-gen-dimlay - defaults for dimension layer
open in text editor and type somewhere in general attribute
TSIZE 2.5
should work on each new view/laye creation but restart pdms
[QUOTE=RUAV;85768]If user provide anything then this is not default I think. Default is something that is set once for the project and used on creation.
TSIZE 2.5
Tried to place the DRA-GEN-DIMLAY FILE on the Server location L:\pdmsdflts and change to chei 3mm but when create new view its still showing 4mm
and other files need to be checked
q evar pdmsdflts
Environment variable PDMSDFLTS :L:\pdmsdflts C:\AVEVA\Plant\DATA12~1.SP2\pdmsui\DFLTS\
