Draft Module dimensions by command
  • Replies 3 replies
  • Subscribers 5 subscribers
  • Views 24 views
sanjyot
sanjyot over 11 years ago
  • Admin
    Admin over 11 years ago
    Quick example
    NEW LDIM FROM /item1 TO /item2
    will create basic dimension of default East horizontal direction between /item1 and /item2 (by their name) (having in mid that your drawing has North plan=Down direction)
    If you need the same but in vertical (for same driction of view) then
    NEW LDIM DIR N FROM /item3 TO /item4
    The same you can do attaching to points like
    NEW LDIM DIR N FROM P1 OF /item3 TO P2 OF /item4
  • sanjyot
    Hi all,
    How can I give dimensions in draft by using command line?
  • sanjyot
    Thanx RUAV...
