Hi all..
i m facing one problem while extracting dxf file from draft..
i have given different colors to GLAB and other notes and dimensions
but when i extract that sheet in to DXF, different colors appear in dxf from the actual that i gave in draft...
can any one tell me how to solve this problem..
hi chennaigru...
i did everything u said...
loaded all the .lsp file, but when i type pdms_color commad in autocad it says "no pdms layer found"...
dont know what to do next...pla help
[QUOTE=siddharth4959;86245]hi chennaigru...
may be you created your dxf file configurable? Command "PDMS_COLOR" works only for standard output of dxf
May sound silly.....but did you open the drawing and typed PDMS_COLOR or typed it in a blank drawing ?
yes chennaiguru..i opened the drawing and then typed pdms_color, but i was working on configurable dxf..
as per suggestion of [COLOR=#333333]sergey_b007, i created standard dxf and my problem is solved...
[/COLOR]
thanks again dude..
