Draft Module
adding drawlist elements manually using notepad file
5 subscribers
Cary Kriston
over 11 years ago
Cary Kriston
over 11 years ago
Hi all,
I generated a report from the design module which is having the atta,valve,instrument,damper etc. n
Each one is named.
I extracted the names from that csv file and copied into notepad file.
is it possible to add the members (atta,valve,instrument,damper etc) into the drawlist which is created in the draft?.
if so please let me know
regards
cary
Henrik Landström
over 11 years ago
Format the list of names as:
ADD /TESTAAAA111
ADD /PPP1333
Navigate to the IDLI you want to add them to, and run the saved file.
