Export Draft > DWG/DXF - problem with font width
Parents
  • sir try this one, i just get from the macro im using now.. Im not admin not so familiar, maybe it can help..
    its a pmlfrm.. try if this work with you..
    setup form !!pdfplot  size 30 0
    !this.formtitle     = 'DRAFT'
    !this.initcall = '!this.init()'
    BAR
    !this.bar.add('macro','menu1')
    menu .menu1
    !this.menu1.add('callback','reload','pml reload form!!pdfplot')
             rgroup .acom   at xmin form 'PDF'
            add tag 'VIEW' select 'view'
             add tag 'NO VIEW'   select 'nview'
        exit
    path down
    button .copying2 at xmin form  'EXPORT PDF DXF PLT' callback '!this.export()'
    path down
    text .tira at x 0  width 20 is string
    exit
    SHOW!!pdfplot
    define method .init()
    !this.tira.val = 'D:\PLOT'
    --!this.hor1.callback='!this.hor1com()'
    --- !this.hor2.callback='!this.hor2com()'
     -- !this.hor3.callback='!this.hor3com()'
    endmethod
    define method .export()
    shee
    var!shee shee
    var!namx namn
    var!namd replace(|$!namx|, |/|,|.|)
    !ff = !this.tira.val
    !x = '$!namd' + '.pdf'
    !y = '$!namd' + '.plt'
    !z = '$!namd' + '.dxf'
       if  !this.acom.Selection() eq 'view' then
    !vv = 'VIEW'
    else
    !vv = 'NOVIEW'
    endif
    view 1
    lframe false
    var!ffx vsca
    !fff = !ffx.real()
    !ss = 1 / !fff
    !ffff = !ss.nint()
    $!shee
    $p SCALE UP $!ffff
    PLOT ce pdf /$!ff\$!x 'MINL 0.22,COL BW,$!vv' A0 OVER
    PLOT ce /$!ff\$!y  A0  CUTM OFF OVER
    PLOT ce DXF /$!ff\$!z ACAD ZCOORD EUC SCALEUP $!ffff OVER
    endmethod
Reply
    BAR
    menu .menu1
        exit
    path down
    path down
    exit
    SHOW!!pdfplot
    endmethod
    shee
    var!shee shee
    var!namx namn
    !vv = 'VIEW'
    else
    !vv = 'NOVIEW'
    endif
    view 1
    lframe false
    var!ffx vsca
    !fff = !ffx.real()
    !ss = 1 / !fff
    !ffff = !ss.nint()
    $!shee
    $p SCALE UP $!ffff
    endmethod
Children
