Draft Module Find Equipment in VIEW
  • Replies 5 replies
  • Subscribers 5 subscribers
  • Views 18 views
Jayson Montajes
Jayson Montajes over 10 years ago
  • Admin
    Admin over 10 years ago
    I maybe reading this thread wrong but 'rrul' does the same thing? just amend 'criteria' to suit your needs?
  • Jayson Montajes
    Hi All,
    I would like to ask if PML.Net has a command like q find /element in viewname?
    My purpose is I want to filter all equipment is it is visible in the view,
    then if it is visible in view I will put a SLAB on it..
    Please help me. I badly need it.
    All response will be appreciated.
    Thanks,
    JaysonX96
  • Bobby Nguyen
    Bobby Nguyen over 10 years ago
    You can try this
    !ori = ce!Tmrf = /YOUR-LABEL
    !v = view
    !view = !v.fullname
           var !vscan vscan for all (EQUI) FOR VIEW
        Do !y indices !vscan
           $!vscan[$!y]
        SWITCH
    $!view
    new laye $!view/EQUI
    handle any
        skip
    endhandle
        new slab DDNA $!vscan[$!y] Tmrf $!Tmrf xypos 10 10
    Enddo
        Refresh
    $!ori
  • Jayson Montajes
    bobby,
    Thanks for your response. I appreciate your PML code.
    But, is there any c# syntax for your solution? I am using c# now.
    Thanks,
    JaysonX96
  • Jayson Montajes
    RRUL is just for the representation. what I need is the C#.net command to collect All Visible equipment in the view.
    Hope anyone here know the solution thanks a lot
