Draft Module Primitive Storage
  • Replies 6 replies
  • Subscribers 5 subscribers
  • Views 16 views
Primitive Storage
Mark Hamiton
Mark Hamiton over 10 years ago
  • Mark Hamiton
    What is causing my primitives to not be stored under my current VNOT? It places them in the top VNOT in the layer. Is this a new feature in 12.1 sp2? Is it a bug? Can it be fixed?
    Try reading this post:
    http://52.178.132.139/showthread.php?t=12927
    HTH
  • Mark Hamiton
    I had read that post already, I am using 12.1 sp2 and from that post I was under the impression that if I turned off the layer control toolbar then it would work properly, but It still wants to place my primitives in the first VNOT that it finds.
    You should keep layer toolbar opened...
    Sorry I have posted my answer before it was finished!
    You should keep layer toolbar opened and in there you have to select the desired VNOT
    Here I am, back to you again!
    I have checked internally and I have found that this was a known bug for 12.1.Sp2
    It has been addressed with Fix 25.
    HTH
