Hi Guru,
Good day.How to measure distance in pdms draft? sometimes I need to know the distance in 2d draft. what i used is measure on design and then divide the value on the scale I used in draft to get the distance unit.. any easier method to do this? thanks in advance..
thanks keyan, but it gives the position of the two points i pick on draft. to get the distance i need to subtract the value to get the x and y distance..dont know how to edit this form..thanks in advnce
thanks sir corrado, it helps a lot but it give the hypotenuse distance, need to compute the x and y ortho distance..i need x and y distance, it helps but i need to subtract the value of x and y..
