Hi I have same problem before, and the solution is by using glab..set lframe to false, and just adjust llclearance.. after you make 1 vertical and horizontal centerline, just copy it using .. new glab copy pre ddnam id@ --> then pick the primitives.. once the object moves just updates annotation and all will follow the obj. hope it helps you.. cheers.
