Draft Module Adding image in Draft
  • Replies 9 replies
  • Subscribers 5 subscribers
  • Views 32 views
Craig Onslow
Craig Onslow over 9 years ago
  • Craig Onslow
    Hi, does anyone know if this is possible? I see there is a IMGELE at SHEE level but I don't know what to do with it. NEW IMGELE is not allowed.
    We have a problem with a Client LOGO wrt resolution. Making a SYMB for the LOGO doesn't work.
  • Venkata Rao Peta
    Venkata Rao Peta over 9 years ago
    you have the autocad file for this client logo.
    then you can tranfer this to pdms draft.
    Already the process discussed number of time on the forum.
  • Craig Onslow
    read my post again
  • Venkata Rao Peta
    hi,
    i read the post really i don't know about IMGELE, It is protected by default by aveva it seems.
    client logo you can shift to draft through some commands in autocad.if you have autocad file.
    image you can't transfer directly to draft
  • Craig Onslow
    There is a problem when I make a Symbol of the logo. When I save as PDF you can't see the writing (it's too small).
    But when I add image in Acad and print, it's okay. The image prints fine but the symbol doesn't. :Not_Impressed:
  • Venkata Rao Peta
    logo you have to explode and transfer to draft through some specific commands.
    later you have to outline the logo in order to get the results in draft.
  • shrinivas balu jadhav
    shrinivas balu jadhav over 9 years ago
    Dear Deva,
           I have read the all topic adding Image / logo in draft,but i cant understand.
           can you give me some steps to outline the logo in order to get the results in draft.
    Thanks in advance,
    Regards,
    Shrinivas Jadhav
  • Venkata Rao Peta
    from the ACAD command line type in APPLOAD
    A form will pop up, navigate to C:\Aveva\Plant\PDMS12.1.SP2\AutoDRAFTACAD and select all six lsp files these being as follows
    pdmsback.lsp
    pdmsdraw.lsp
    pdmsgeom.lsp
    pdmsquit.lsp
    pdmssymb.lsp
    pdmsutil.lsp
    Once selected click on the load button and close the form down. The directory will vary dependent upon the version of PDMS you are using but the changes should be self evident.
    Load the appropriate drawing border into AutoCAD and type the command EXPLODE ALL
    Now type in PDMS_SHEET ALL on the Command Line
    A series of questions will be asked and they will obviously change depending upon your requirements.
    Inch/
    Dear Deva,
             Thanks for reply,
             I have tried these steps,I have imported symbol is with no of STRA primitives.so now we want to hatch particular symbol letters.Please guide either to import from auto cad as outline or create outline in pdms and hatch symbol letters.
