Draft Module Split pipe to several sheets?
  • Replies 3 replies
  • Subscribers 5 subscribers
  • Views 27 views
Henrik Landström
Henrik Landström over 9 years ago
  • Henrik Landström
    Hi
    I'm trying to split a pipe, so that I get a controlled amount of branch members on each sheet. Problem I have is that I can't control which tubis are to be shown...
    If I had only bran members, I get no tubes in Draw, if I add the entire branch, I don't know how to hide some tubis (elbows etc. are easy to add as rem elements into the drawlist)
    The view direction is always some ISO view.
    Is it possible to solve this i Draw without using cutting planes? (will be quite many and complicated stepped planes...)
    One way is to split the pipe in Model, one branch for each sheet...but trying no keep the work in Draw if possible.
  • Admin
    Admin over 9 years ago
    you can use macro or you insert atta as break limit
  • Henrik Landström
    I didnt explain it all to well, but Im talking about sheets in Draw/Draft not generated by IsoDraft.
