Auto Drawing Production (ADP)
  • This is Step for Creating Auto Drawing Production in Draft module PDMS and  E3D :
    - Create --> General ADP
    - Create Drawing
    - Create Sheet
    - Create View
    [ATTACH=CONFIG]9112[/ATTACH]
  • - In View please set your ADP View :
    [ATTACH=CONFIG]9113[/ATTACH]
  • - Click ADP Tagging
    [ATTACH=CONFIG]9114[/ATTACH]
  • - Click ADP Schedules :
    [ATTACH=CONFIG]9115[/ATTACH]
  • - click Apply
    - click Update
    [ATTACH=CONFIG]9116[/ATTACH]
    [ATTACH=CONFIG]9117[/ATTACH]
  • -- Created by Mansyur Usman for BTS Project
    -- General Defaults For Area Based ABA Use.
    -- Section 1
    !!abaDefaults.libr.val = '/Aba/graphical_reports_library'
    !!abaDefaults.dlib.val = '/Aba/drawing_template_library'
    !!abaDefaults.alib.val = '/Aba/area_definition_library'
    !!abaDefaults.disl.val = '/Aba/disciplines_library'
    !!abaDefaults.keyp.val = '/Aba/keyplans_library'
    !!abaDefaults.symb.val = '/Aba/symbols_library'
    !!abaDefaults.labl.val = '/Aba/tag_rule_library'
    !!abaDefaults.task.val = '/Aba/task_library'
    !!abaDefaults.logf.val = '%PDMSABALOG%'
    !!abaDefaults.batf.val = '%PDMSABABATCH%'
    !!abaDefaults.logPath  = '%PDMSABALOG%'
    !!abaDefaults.batPath  = '%PDMSABABATCH%'
    !!abaDefaults.ustring  = 'SYSTEM'
    !!abaDefaults.string   = 'XXXXXX'
    !!abaDefaults.startbat = '%PDMSABABATCH%\pdmsBatch.bat'
    -- End Section 1
    -- Permitted View Scales
    -- Section 2
    Metric        \MET  \1/1             \1 1            \1
    Metric        \MET  \1/2             \1 2            \0.5
    Metric        \MET  \1/3             \1 3            \0.333333,0.3333,0.33
    Metric        \MET  \1/5             \1 5            \0.2
    Metric        \MET  \1/10            \1 10           \0.1
    Metric        \MET  \1/20            \1 20           \0.05
    Metric        \MET  \1/25            \1 25           \0.04
    Metric        \MET  \1/33.1/3        \1 33.1/3       \0.0303,0.03
    Metric        \MET  \1/50            \1 50           \0.02
    Metric        \MET  \1/75            \1 75           \0.013333,0.0133,0.013
    Metric        \MET  \1/100           \1 100          \0.01
    Metric        \MET  \1/150           \1 150          \0.006667,0.0067
    Metric        \MET  \1/200           \1 200          \0.005
    Metric        \MET  \1/250           \1 250          \0.004
    Metric        \MET  \1/500           \1 500          \0.002
    Metric        \MET  \1/1000          \1 1000         \0.001
    Metric        \MET  \1/1250          \1 1250         \0.0008
    Metric        \MET  \1/2500          \1 2500         \0.0004
    Architectural \ARC  \3"     = 1'-0"  \3Inch 1'       \0.25
    Architectural \ARC  \1 1/2" = 1'-0"  \1.1/2Inch 1'   \0.125
    Architectural \ARC  \1"     = 1'-0"  \1Inch 1'       \0.083333,0.0833
    Architectural \ARC  \3/4"   = 1'-0"  \0.3/4Inch 1'   \0.0625
    Architectural \ARC  \1/2"   = 1'-0"  \0.1/2Inch 1'   \0.041667,0.0417
    Architectural \ARC  \3/8"   = 1'-0"  \0.3/8Inch 1'   \0.03125 ,0.0313
    Architectural \ARC  \1/4"   = 1'-0"  \0.1/4Inch 1'   \0.020833,0.0208
    Architectural \ARC  \3/16"  = 1'-0"  \0.3/16Inch 1'  \0.015625,0.0156
    Architectural \ARC  \1/8"   = 1'-0"  \0.1/8Inch 1'   \0.010417,0.0104
    Architectural \ARC  \1/16"  = 1'-0"  \0.1/16Inch 1'  \0.005208,0.0052
    Engineering   \ENG  \1" = 10'-0"     \1Inch 10'      \0.008333,0.0083
    Engineering   \ENG  \1" = 20'-0"     \1Inch 20'      \0.004167,0.0042
    Engineering   \ENG  \1" = 30'-0"     \1Inch 30'      \0.002778,0.0028
    Engineering   \ENG  \1" = 40'-0"     \1Inch 40'      \0.002083,0.002
    Engineering   \ENG  \1" = 50'-0"     \1Inch 50'      \0.001667,0.0017
    Engineering   \ENG  \1" = 60'-0"     \1Inch 60'      \0.001389,0.0014
    Engineering   \ENG  \1" = 75'-0"     \1Inch 75'      \0.001111,0.0011
    Engineering   \ENG  \1" = 100'-0"    \1Inch 100'     \0.000833,0.0008
    -- End Section 2
    -- Symbol Templates
    -- Section 3
    -- Plan View E/W axis
    /Aba/SAM/grids/EW
    -- Plan View N/S axis
    /Aba/SAM/grids/NS
    -- Elevation View EW axis
    /Aba/SAM/grids/vert_EW
    -- Elevation View NS axis
    /Aba/SAM/grids/vert_NS
    -- North Arrow
    /Aba/north_arrow
    -- End Section 3
    -- Auto Number Task
    -- Section 4
    /Aba/AutoNumber
    -- End Section 4
    -- Imperial Paper Sizes
    -- Section 5
    A \8.5 11
    B \17 11
    C \22 17
    D \34 22
    E \44 34
    -- End Section 5
    -- Metric Paper Sizes
    -- Section 6
    A0 \1189 841
    A1 \841 594
    A2 \594 420
    A3 \420 297
    A4 \297 210
    A5 \210 148
    -- End Section 6
  • the first you must create --> Area Based ADP Defaults...
  • Like This below :
    [ATTACH=CONFIG]9363[/ATTACH]
  • after that create : Create-->Area ADP Library --> Area Library…
