[COLOR=#333333]I see your name a lot at the forum and was thinking maybe I can post you directly.[/COLOR]
[COLOR=#333333]My name is Lex Rotteveel and I am working for a company named Frames Gas Processing in the Netherlands. [/COLOR]
[COLOR=#333333]I am working for almost 2.5 year with PDMS now.[/COLOR]
[COLOR=#333333]PDMS version: 12.1.SP2.32[/COLOR]
[COLOR=#333333]Problem: Draft conversion to Autocad[/COLOR]
[COLOR=#333333]Using following menu: Utilities -> Configurable DXF/DWG CE... (file output DWG, Select Directory)[/COLOR]
[COLOR=#333333]Problem: In draft my view is very clear thin lines good quality etc. when I open the generated dwg drawing the lines are very thick and the quality is very low it is hard to recognize the items in the dwg drawing.[/COLOR]
