Draft Module Slab leader repositioning
  • Replies 9 replies
  • Subscribers 5 subscribers
  • Views 17 views
Nico Haavisto
Nico Haavisto over 9 years ago
  • Admin
    Admin over 9 years ago
    You can use modify, this will highlight grips on the leaderline, use cursor to adjust position.
    Also you can use apoffset, in command line, use Q ATT and adjust apoffset values
  • Admin
    I haven't used marine draft so not sure if different from general draft.
    With slab your ce, in command line type q att, in general draft we can see APOFFSET BPOFFSET & CPOFFSET.
    If the attributes says:
    Apoffset unset
    You can change to:
    Apoffset 10mm 0mm
    APOFFSET BPOFFSET & CPOFFSET all have x y positions
    Hope this helps
  • Admin
    In command line does modify$@ work for you
  • Nico Haavisto
    Hello again gurus.
    I have a slab that's connected to a bent panel showing its item No.
    I'd like to reposition the leaderline without losing the connection
    to the panel. is this possible with cursor positioning or some other way?
    Thank you again!
  • Nico Haavisto
    Those are good ideas but I'm forced to use marine draft and I haven't been able to find the
    modify tool in here. That was my goto tool for this operation as well.
    And what comes to apoffset it says 'cursor input invalid at this stage'. So no help there either.
    Any more ideas? :)
  • Nico Haavisto
    Hi.
    Yes I'm aware of these attributes and I normally use themn in outfitting draft as well.
    apoffset works if I give it the offset by hand (apoffset 10 20) but I'd like to give it with cursor so that
    I don't need to guess the right values to the attribute. But for some reason the simple 'apoffset @' command won't
    let me input the cursor point. I don't know why it doesn't work but I'm looking for a similar solution.
  • Nico Haavisto
    No it gives syntax error :S
  • Carl-Henrik Sjöqvist
    Carl-Henrik Sjöqvist over 9 years ago
    If you haven't resolved it yet; "LEAD ATTA @" might be the trick for you.
  • Nico Haavisto
    I have resolved it actually. there is a function for it in marine draft.
    And the solution you were offering actually ended with fatal error :D
    so that didn't work either.
