Draft Module Line weight in draft
  • Replies 7 replies
  • Subscribers 5 subscribers
  • Views 38 views
VINOTH BASKARAN
VINOTH BASKARAN over 9 years ago
  • VINOTH BASKARAN
    How to show thin & thick lines in draft ?
  • MOHAMED AUSWATH KHAN Z
    MOHAMED AUSWATH KHAN Z over 9 years ago
    Using the Styl element in the draft can be achieved
  • VINOTH BASKARAN
    Thank You @mecauswath92z. I did that.. but not able to convert the same line width settings into pdf.. is there any plugin or plot settings available to show line width differences in PDF format ?
    What version of PDMS are you using and how you are plotting the PDf.
  • VINOTH BASKARAN
    version is 12.1.SP4.29
    Using utilities =>print ce
    Use Plot ce option to plot the file in PDF.Click Plotter within dialog box and followed by other to print in PDF.
  • B SREENIVASULU
    B SREENIVASULU over 6 years ago
    printed converted pdf copy. Not able see line weights differences in print as it was assigned in styles.
    Any settings, we have to do further..
