Draft module custom (shortcut) menu
  • Can anyone help me with a customized or (shortcut) type menu for DRAFT.
    My company has little to no customizations done and this makes things rather tedious
    Would love to have a menu with Labels assigned for such things as PIPE, EQUIPMENT, TOS. etc.
    that already has box off, line on, arrowhead set etc..
    also is there a form for filling out UDA's rather that having to do it by Q ATT at sheet level?
  • [QUOTE=kimmillerusa;100873]Can anyone help me with a customized or (shortcut) type menu for DRAFT.
    Although it may seem tedious there are some good things in having no customization.
    For example you may use the latest version of PDMS available since you will probably have no issue with little or no existing customization, taking advantage of the latest features available.
    I would recommend you to attend a PML Training first before starting to start the customization works.
    Check with your local office.
    Yes, it is possible to create a form to change all the relevant UDAs in a more user friendly way.
    This is a good reason to attend the PML Training.
    Anyway you will find lots of examples of forms and macros in this forum which may suit your needs.
