Draft Module View section properties
  • Replies 11 replies
  • Subscribers 5 subscribers
  • Views 29 views
ingebrigt farstad
ingebrigt farstad over 9 years ago
  • ingebrigt farstad
    Is there a way to make a section cut only affekt some elements in the view?
    Corrado Galluzzi over 9 years ago
    You need to create a specific drawlist and assign it to the VSEC element
    It should work ok.
    Which PDMS version are you using (Q BANN on the command window...)
  • ingebrigt farstad
    Hi
    Thanks but i had a problem doing that. Seems that the VSEC gets disabled when assigning a different IDLName (different from view drawlist)
    Not getting any errors
    -What am I doing wrong?
  • ingebrigt farstad
    OK, here we are:
    AVEVA PDMS Draft Mk12.1.SP2.36[8363]
    Could there be some other attribute i should check?
    PMODE attribute of VSEC to be Standard or Reversed. Not Off.
  • ingebrigt farstad
    Hi. No luck on this one, thanks anyway.
  • Bruce Findlay
    Bruce Findlay over 9 years ago
    If they are in the same framework it won't work.
    Let's say you want to cut a Panel element only, you have to add the owning FRMW element to the drawlist
  • ingebrigt farstad
    Hi again.
    Do I need to separate the cut elements into different frameworks?
