HELLO, DEAR all, we are facing an unpleasant issue with the generation of a pipe isometric.
I did some research, but I've seen a lot of discussion about how to get the idf file. What I'm searching is how to interpret it.
This file is for testing a line.
How can I interpret this?
my best regards!!
What do you mean with "how to interpret it"?
I mean, where can I find if my pipe has any errors in it?
Does this file indicate something similar?
connection erros, flow sense inconsistency, any pipe inconsistency ?
I see only numbers in the file
For that kind of checks you need to use Data Consistency command.
IDF files allow you to export iso information to external packages as Spoolgen
