Draft Module Draft from PDMS to E3D
  • Replies 3 replies
  • Subscribers 5 subscribers
  • Views 24 views
Nguyen Hong Anh
Nguyen Hong Anh over 7 years ago
  • Nguyen Hong Anh
    hi guru
    I'm using PDMS 12.1.SP4 and E3D 2.1
    when login module draft on pdms everything ok but login the same project on draw module E3d it's occur error:
    Draw is not available for use in the project XXX
    Contact your administrator to make Draw available in this project.
    I tried to create new database on draft module but it's not success.
    Help me. i'm just begin E3D one week ago
    Corrado Galluzzi over 7 years ago
    You need to enter Admin (E3D2.1) and DRAW Module will be created automatically.
    This definition is achieved by opening the migrated Project in AVEVA Administration 1.4 and performing a Savework. The Draw module is automatically defined at this point.
    This comes from the AVEVA Everything3D? 2.1 Migration & Interoperability Guide that you can require to your Aveva Local Office
  • Nguyen Hong Anh
    You are correct. We need to enter admin module first.
    Thank you corrado
