Draft Module Problem deleting a SLAB
  • Replies 2 replies
  • Subscribers 5 subscribers
  • Views 5 views
David James Broughton
David James Broughton over 7 years ago
  • David James Broughton
    Hi,
    Is it possible to delete a SLAB which has a TAGR associated with it?
    Cheers.
  • Azmatulla Mirza Baig
    Azmatulla Mirza Baig over 7 years ago
    You need to remove the TAGR before trying to delete the SLAB.
    Use this command in sequence in the command window.
    SORF =0
    DELETE SLAB
     Else
    You can delete all the SLAB for the Layer by navigating on the Layer and using the Delete>>Members option from the menu.
