Draft Module Copy and include glab or slab
  • Replies 3 replies
  • Subscribers 5 subscribers
  • Views 35 views
mohd khaidzir bin mohd yusoff
mohd khaidzir bin mohd yusoff over 5 years ago
  • mohd khaidzir bin mohd yusoff
    Hi Guru,
    I'm have problem to copy slab or glab by list from view to view.
    Any command or code work able to use?
    Thanks.
  • M Michal
    M Michal over 5 years ago
    First possibility is command " COPY MEMBERS 1 TO 6 OF /NAME_OF_LAYE " NAME_OF_LAYE is laye from u want to copy. And u need stay at laye where u want to copy. Problem is u need to have all glabs / slabs in single laye.
    Second options is for example this
    VAR 1 NAME
    do !X values !!CDLIST1
    $!X
    VAR 2 NAME
    $V1
    new glab copy $V2
    enddo
    Just put that code into file, create list/collections of glabs u want, then stand on laye where u want to put it in and put that file onto command line (NOT in that action line in list/collection)
    - - - Updated - - -
    And here, with this u can put glabs, slabs into single list.
    VAR 1 NAME
    $!X
    VAR 2 NAME
    VAR 3 TYPE
    $V1
    new $V3 copy $V2
    enddo
  • Venkata Rao Peta
    hi Kidit,
    In E3D you don't have an option for list as in PDMS.
    In E3D if you want to use list, use [COLOR=#a52a2a]show !!cdclist[/COLOR]
