Draft Module
View limits problem
5 subscribers
View limits problem
mohamed sambo mahmoud
over 5 years ago
over 5 years ago
I set my limits for ex a coluomn to show section between 2 elevations ( u 2500 to u 2300 ) and looking down , but th problem u 2300 does not work and the whole coloumn appears ?
Thanks in advance
Venkata Rao Peta
over 5 years ago
It should work, is it possible to work with new sheet.
i found these type of issues while updating sheets, when there is a new sheet creation this will not occur.
have a try
over 5 years ago
thanks Deva i will try and give you a feed back
over 5 years ago
Still the same problem
Karthikeyan Soundara Pandiyan
over 5 years ago
have u set the view to 'universal hidden line ' option, if you have set as 'wireline' then the view wont be cut at desired elevation
over 5 years ago
THANK kARTHIKEYAN I HAVE TRIED AGAIN AND IT WORKS NOW WITH 2 OPTIONS UNIVERSAL OR GLOBAL :D
