Hi All,
i need to create quick projection view through commands.is there any command exist to create projection view
Thanks
Hi All,
Thanks
Quick view projection is step wise process, select view and identify projection with coordinates or shared drawlist.
may be direct command will not exist.
Viewdir command helps if main view is ortho...
need to create detail for each steel sctn( sometimes other type also coming like panel of supports). orientation and cutting angle of the item is not common. to automate the detail creation i required this.
