I'm trying to configure a backing sheet with revision "intelligent text". When you create a revision, using the Revision Control window, you can described the "Reason for Revision". I would like to retrieve that string and display it in our revision block. I can't see that attribute in the intelligent text window, under the "Drawing" section... Is there any way to display that field?
