Noted Dimension
Hello
I've been working on structural drawings and its usual to note some dimensions for e.g. spans indications.
as noted in the image bellow, I have to write a text, different to the LDIM element, to note the dimension. I've tried to edit the DMTXT value, but it's forbidden by the system.  or you use #DEF or custom text, but not a mix of it.
is there a way to make a note in the dimension without lose the intelligence of the element?
thanks in advance
kind regards
