Draw View update command
  • Replies 6 replies
  • Subscribers 6 subscribers
  • Views 55 views
View update command
Tamizhazhagan
Tamizhazhagan over 6 years ago
  • Tamizhazhagan
    I created new view and set limits, drawlist, style and etc... In command line. Then I had put "UPDATE ALL" in command line, but view is not update. Please help .
  • Venkata Rao Peta
    Stand on the view and Try
    UPDATE DESIGN
    SAVEWORK
  • Tamizhazhagan
    Hi deva,
    I used in pml macro but graphics not updated
  • Tamizhazhagan
    i have to used below commands in pml macro
    CALLDRG ULIMITS SETLIMITS _CDROVIEW
    CALLDRG ULIMITS SETTHPOS _CDROVIEW
    CALLIBM UUPDATE DESIGN
  • Nguyen Hong Anh
    Nguyen Hong Anh over 6 years ago
    i met this issue too. who can give me some advices?
  • Jose Contreras
    Jose Contreras over 6 years ago
    I think we need a little more information. Typically I would confirm that the view had a drawlist associated with the view. Then I would make sure the view RRSF attribute has been set.
    If the view still doesn't update. Then I would check out the rules themselves. What are the rule criterias? For example, are they calling for all pipe with a specific attribute like the Purp of the site be set to "PIPE".
    Finally, I would check to make sure I don't have any incorrect vsecs.
    Also, I almost forgot, make sure you have assigned a valid VTYPE at the view.
    If you are still having issues. May I suggest you post an output file of the view. Maybe someone can point out something.
    Good luck
