Draw Slab layer
  • Replies 14 replies
  • Subscribers 6 subscribers
  • Views 72 views
Slab layer
Artem Yadegarian
Artem Yadegarian over 4 years ago
    Sorry if I ask you this for the third time...
    Why do you need to store your labels into a specific layer?
    Maybe we can suggest you a different way to reach your goal even keeping all the labels in the same layer
  • Artem Yadegarian
    I?m not using Auto tagging. It is only tagging with slab and I need to put the tag under a certain layer . I am aware after slab tagging I can move them Uber preferred layer but my question is why software won?t put the tag under my current active layer?
  • Artem Yadegarian
    It would be easier and faster if you could Change the visual style of all equi  tags or change the visual style of all instrument tags. Because you could select all the equi slabs under a certain layer and change the visual style of equi slabs which is located under a certain layer in one shot. This was one example.
    Thank you, it is clear now.
    Have you tried using the "Power Selector" tool?
    You can find it into the Display Group at the right hand side of the Home Tab.
    I am sure this will help you.
    Please let us know..
