Draw Slab layer
  • Replies 14 replies
  • Subscribers 6 subscribers
  • Views 68 views
Slab layer
Artem Yadegarian
Artem Yadegarian over 4 years ago
  • Artem Yadegarian
    When I bring in a slab thru ANNOTATE > SLAB ; Slab is going under a random layer under a certain view which is activated. Is there any way to direct a slab to a certain layer under view?
  • Matts Nordman
    Matts Nordman over 4 years ago
    No, there is no way to get Draw to do what Draft used to do. Draw was originally meant to be operated without the Draw explorer, which is also why it places labels and other elements not randomly as you suggest but in a certain layer. It will also always place labels under the view which is selected as the current owner.
  • Artem Yadegarian
    We are ending up moving Slabs into their respected layer manually or with macros. But my question is why AVEVA has not thought about that!
  • Matts Nordman
    I think you have a valid question. You should ask Aveva what they think, they are reasonable people and they will listen to reason.
    May I know why do you need to move labels on specific layers?
    What's wrong with layers?
    PDMS was developed in the 70's and they decided to have "layers".
    Then all the other CAD applications followed.
    In Draft (and Draw) they are just  storage places for labels, dimensions etc etc.
    They could have called them "folders", "boxes" and so on.
    But they called them layers.
  • Artem Yadegarian
    Why we have layers under View in AVEVA draw ? Why we have layers in all cad based applications?
  • Artem Yadegarian
    So I am trying to put the Instrumentation Slabs under dedicated Instrumentation layer and equipemnt slabs under equipment layer under so on under each view. But the question is : when I use ANNOTATE > SLAB the generated slab goes into random layer ; even it is not going to our current layer !
  • Matts Nordman
    I already answered that, there is no way to get Draw to do that out of the box. This is true for most of the functions in the ribbon bar, they do not use the current element.
    May I  ask you why?
    Anyway...
    One possibility is using Autotagging functionality.
    You can have one autotagging rule per layer.
    And you can create as many layers as you want.
    One rule for instruments-->Instrument layer
    One rule for equipment-->Equipment Layer
    and so on...
